bernd
You didn't tell us in which environment you try to do a post layout simulation. Is it pure Mentor, Calibre and Eldo or is it mixed Mentor and Cadence, Calibre and Spectre.
> I want to make a post-layout simulation in Calibre. The simulation has to be done with a simulator Eldo or Specrte in this case, Calibre is just the LVS and Extraction tool.
An additional hint to Pauls input, if you use a mixed Mentor and Cadence environment you should rather use the Hierarchy Editor with the config view to alter the switch view list then doing this over the Environment Setup. This allows you to directly probe your extracted netist in the schematic at least with Assura and Spectre.
Bernd
