Aug 14th, 2024, 5:23pm
Eldo RF Phase Noise DSB/SSB definition confusion (Read 3267 times)
neoflash
Mixed-Signal
Designer
Dec 05th, 2005, 6:38am
Hi, Folks:
I am using eldo_rf to simulate the phase noise of ring oscillator.
It will generate report as sphi and sphi_ssb. According to definition, single side band noise should be 3db greater than double side band noise.
However, the results are reversed.
db(Sphi_dsb) = db(Sphi_ssb)+3dB;
I believe Mentor have a bug, any one know more information on this bug?
thanks
vborich
Re: Eldo RF Phase Noise DSB/SSB definition confusi
Reply #1 - Dec 5th, 2005, 12:45pm
There is widespread confusion regarding this topic.
Technically, phase noise is short for Spectral density of phase noise. You'll commonly see this denoted as
S_phi(f) in technical literature. On the other hand, designers usually refer to the noise-to-carrier ratio Lambda(f) simply as "phase noise", even though this quantity measures the total noise power at offset f and therefore includes the contribution, however small, of amplitude noise as well.
In the small-angle approximation, and assuming negligible amplitude noise, S_phi(f) is twice the noise-to-carrier ratio at small offsets or, equivalently, 3 dB HIGHER.
Because the noise power in the noise-to-carrier ratio definition is measured in a single sideband, and because S_phi(f) approximatelly equals twice the single sideband noise-to-carrier ratio, and because the noise-to-carrier ratio is usually referred to as "phase noise", S_phi(f) has come to be known as "double-sideband phase noise".
So Eldo-RF is indeed correct.
Your simulator may in fact compute just one quantity and simply scale the other by 3 dB. Or it could take a more rigorous approach and compute both of them directly. It's easy to verify: Sweep your analysis over a broad range until you hit the noise floor, and then plot them on the same graph. You'll see ~3dB difference near carrier and then the plots will slowly diverge as you approach the knee.
Vuk
