Neo_flash,
You are correct that if the signal was periodic then there would be no pulse distortion. However in general signals is not truly periodic, they are random. This is why standards specify pseudo-random data, PRBS, data for testing bit error rates.
So if there is a system with a pulse input, the output pulse will be distorted unless the group delay of the system is constant. The pulse distortion is dependent on the data pattern, for example, the distortion for the data patterns 01010101 and 00001111 are different[if the group delay is not constant for two octaves]. When the outputs for the different data patterns are overlayed, the pulse distortion appears as jitter. Even if the communication channel is perfect, systems usually have internal filtering that causes pulse distortion, for example, the channel filter in Bluetooth/GSM. The result is that systems have systematic jitter that typically comes from the system specification, for example, 1 MHz channel spacing, 20dB of attenuation in the next adjecent channel, Bit error rate of 0.1%, ...
