May 1st, 2024, 3:32pm
CCCS in verilog AMS not working (Read 2810 times)
Saroj Rout
Guest
Dec 29th, 2005, 2:31pm
I am modeling a current-controlled-current-source in the following way.
`include "disciplines.vams"
`include "constants.vams"
module cccs_int (inp,inn,outp,outn)
input inp;
input inn;
output outp;
output outn;
electrical inp;
electrical inn;
electrical outp;
electrical outn;
parameter gain=1.0;
analog begin
    I(outp,outn) <+ gain*I(inp,inn);
When I terminate the output with a resistor it seems to be working fine. But when I terminat it with a capacitor, I was expecting a integrated output but the output seems to be some very High constant voltage instead.
Does anybody know why the cap is not integrating the output of the controlled current source ?
Thanks in advance.
  IP Logged
Re: CCCS in verilog AMS not working
Reply #1 - Dec 29th, 2005, 5:24pm
You probably need to give an initial condition on the capacitor. The large voltage on the capacitor probably stems from the initial DC analysis that precedes the transient.
