Aug 15th, 2024, 1:20am
buffer bandwidth in sample-and-hold (Read 3621 times)
steven
Dec 31st, 2005, 1:47pm
I have a question on the buffer bandwidth of sample-and-hold circuit. Assuming that the S/H circuit operates at very high speed, then the buffer should have enough bandwidth to support it. If only focusing on bandwith of the buffer, what kind of buffer amplifier structures can be good options?
Paul
Switzerland
Re: buffer bandwidth in sample-and-hold
Reply #1 - Jan 2nd, 2006, 2:22pm
Hi Steven,
for very highbandwidth, try to minimize the number of parasitic poles. Single-stage structures are most adequate for this. Especially folded-cascode amplifiers provide relatively high gain with a convenient gain-bandwidth product. Also check slew-rate performance, as it may limit the speed of your S&H structure.
Paul
steven
Reply #2 - Jan 2nd, 2006, 9:39pm
Hi Paul,
Thanks for your helpful message. Maybe there is some more to explore here: when facing a choice between folded cascode and telescopic structures, what are the major considerations you would take into account?
Thanks again.
Paul
Switzerland
Reply #3 - Jan 4th, 2006, 1:13pm
Steven,
the telescopic structure has only half the power consumption than the folded cascode topology (due to the absence of the folded branches), but it has a lower signal swing, both at the input and the output. I think telescopic structures are less frequently used in advanced technologies due to reduced supply voltages.
Paul
