Aug 15th, 2024, 11:22am
pNOISE analysis USING CADENCE spectere (Read 3354 times)
rjshmadala
Jan 08th, 2006, 3:37am
Hi Guys,
when i was running pnoise analysis in cadence spctre it saying as below
Internal error found in spctere during p noise analysis please run 'get spectre files' or send the netlist..............
to support@cadence.com
assertion failed in file 'bsim3v3.c'at line 44995
assertion failed.
pss was running correctly
can u guys please solve this issue.
i set the parameters as in cadence manual
http://www.cadence.com/community/virtuoso/resources/SpectreRF_VCO533AN.pdf
but still the error  was coming.
Rjshmadala
Re: pNOISE analysis USING CADENCE spectere
Reply #1 - Jan 9th, 2006, 11:43am
I answered this in http://www.designers-guide.org/Forum/YaBB.pl?num=1136720322. Generally it's not a good idea to post in more than one forum. It tends to lead to confused responses where somebody hasn't seen responses on the other thread.
Forum Administrator
YaBB Administrator
Reply #2 - Jan 9th, 2006, 1:40pm
Please read the Forum guidelines before posting (http://www.designers-guide.org/Forum/guidelines.html).
