rudy.talukder
Mountain View
Hi, I am trying to write a verilog-A model for a circuit that will sense ‘a’ crossing below -17.99V and wait for 4us before the state changes from alive to dead. If it goes above -17.99V before the 4us the state should get restored to alive. If there is a glitch, it should again wait for 4us after the glitch goes away.
I am pasting the testcase.va file below: //////////////////////////////////////////////////////////////////////////////// //////////////////////
`include "discipline.h" module testcase(a,b,c,d,e,f,dummy); inout a,b,c,d,e,f,dummy; electrical a,b,c,d,e,f,dummy; real state,state2; branch(b,c) device; parameter real kill_start = 0.0; parameter real alive = 1.0; parameter real kill_end = 2.0 ; parameter real dead = 3.0; analog begin
@(initial_step) begin state = alive; //alive state initially state2 = alive; end
V(dummy) <+ 0;
@(cross(V(a)+17.99,-1)) begin state = kill_start; //Start of kill end
if(state == kill_start) begin V(dummy) <+ transition(2,4u); //4us is the minimum kill pulse width required end
@(cross(V(a)+17.99,1)) begin state2 = kill_end; end
if((state == kill_start) && (V(dummy) >= 2)) begin //flip the state to dead state = dead; end
if((state == kill_start) && (state2 == kill_end)) begin //insufficient pulse width.flip the state back to alive state = alive; V(dummy) <+ transition(0,0u); end
if(state == dead) begin I(device) <+ (V(b)-V(c))/3185.558 + V(a)*(V(b)-V(c))*0.000095016666667; end
if(state == alive) begin I(device) <+ 0.00; end
end endmodule
I am pasting the testcase.sp file below: ********************************************** * *.param HSIMVERILOGA="testcase.va" .verilog testcase.va
vsource a gnd pwl(0u 0 1u 0 2u 1.1v 5u 1.1v 6u -18v 15u -18v 16u 0v 17u 1.1v 18u 1.1v 19u 5v ) Vsd e gnd pwl(0u 1.2v 1u 1.2v 2u 1.2v 5u 1.2v 6u 1.5v 15u 1.5v 15.5u 1.2v) Vss d gnd pwl(0u 0 1u 0 2u 0 5u 0 6u 1.5v 15u 1.5v 15.5u 0v) Vfc0 b gnd pwl(0u 0 1u 0 2u 0 5u 0 6u 1.5v 15u 1.5v 15.5u 0v) Vfc1 c gnd pwl(0u 1.2v 1u 1.2v 2u 1.2v 5u 1.2v 6u 1.5v 15u 1.5v 15.5u 1.2v) Vpw f gnd pwl(0u 1.2v 1u 1.2v 2u 1.2v 5u 1.2v 6u 1.5v 15u 1.5v 15.5u 1.2v) vgnd gnd 0 0
.model testcase macro language=veriloga y1 testcase a b c d e f dummy *** Simulation Time .tran 10n 60u
.plot TRAN v(*) .plot TRAN i(*) *.print v(*) *.print i(*) .end **************************************************** I am simulating it on eldo. I am getting the following error: 'testcase.va', line 29: Error : Cannot use analog operators or analog event (@) statements inside if or analog event (@) blocks with non-constant conditions.
'testcase.va', line 43: Error : Cannot use analog operators or analog event (@) statements inside if or analog event (@) blocks with non-constant conditions.
testcase.va: module(s) testcase Failed With Errors.
ERROR 1102: VERILOG_A :COMPILER doesn't run successfully, "compiler error with "testcase.va" . stop"
Can someone help me in solving this?
Rudy
