chase.ng
penang/malaysia
A 3-bit full adder is possible just by deriving the circuit from the boolean equation, but that will have more than 2 transistors stack-up on top of each other, which will eventually slowing down the adder instead of speeding them up. This is especially true in high speed domino style tree adder with tight timing window, unless the adder is to be design in SOI technology where body effect is not a concern.
Chase
