Can you find the subckt definition? Don't post any proprietary model parameters here. Presumably, the subckt has parameters W,L,AD,PD, etc.; are they passed directly to the actual MOS element inside the subckt? I'm guessing not, and maybe the equations are confused.
I once found this in a different foundry's subckt for well proximity:
.param xw='1.5e-8' wint='6e-9' weff='l+xw-2*wint'
Note that weff is computed from l instead of w.
