Jul 20th, 2024, 3:12am
minimizing variation in latch turn-on delay (Read 3197 times)
vivkr
Jan 24th, 2006, 7:42am
I am using a simple latch with back-back connected load devices providing +ve feedback
on a diff pair, and a clamping diode.
This latch has a turn-on delay which is dependent on the input common-mode voltage
but the turn-off delay is relatively constant.
Does anyone have any suggestions on how the variation may be minimized?
Vivek
steven
Re: minimizing variation in latch turn-on delay
Reply #1 - Feb 5th, 2006, 8:14am
vivkr wrote on Jan 24th, 2006, 7:42am:
Vivek
Hi Vivek,
So your circuit is a comparator with preamp and latch, right? Have you figured out what to improve the turn-on delay? Does the delay come from the first stage? Because the latch's input is a larger signal.
Steven
vivkr
Reply #2 - Feb 7th, 2006, 3:29am
Hi Steven,
I only have one stage in my comparator. As for the delay variation, normally you have to balance
the PMOS and NMOS devices to adjust the delay skew. In my case, there was skew even despite this.
The reason was that the tail current source (I have a preamp only) had too little headroom during the
large swings. I fixed this by adjusting device sizes and the variation went away.
Normally, this should not have caused a problem if there are complementary inputs on the latch. In my
case, one input was fixed and the other was changing. Hence, there was an inherent asymmetry which was
worsened when the input fall too low, causing small Vds across the tail current, and modulating it.
In a fully differential scenario, the modulation is same in both cases and no net variation is seen.
Vivek
steven
Reply #3 - Feb 7th, 2006, 11:24am
Hi Vivek,
After reading your reply, I realize I have over-complicated the situation. I thought that delay skew might come from either overdrive or what you tried to make a rail-to-rail input comparator.
I guess you have used NMOS as the input differential pair. What if changing to PMOS differential pair (the latch stage changes too)?
Steven
