Jul 20th, 2024, 11:29pm
output resistence of 2-order opamp ? (Read 5164 times)
zhonghan
china
Jan 28th, 2006, 9:06pm
I am confused by such a question : after miler compensating ,the output resistence of  2-order opamp  reduces to  RII/(gm*RII)=1/gm , then if the gain of the second order remains original,  does it  mean the transconductance enlarge RII*gm time ?
vivkr
Re: output resistence of 2-order opamp ?
Reply #1 - Jan 30th, 2006, 5:13am
Not quite clear what you mean by R|| in your post, but I suppose you are saying that
the AC impedance at the output is reduced to 1/Gm due to the shorting action of the
compensating cap at high frequencies.
If so, then you are right. This does happen. But at low frequencies, this is not the case,
and the gain of the 2nd stage is gm2.R||. As the frequency goes up, this gain falls off
after a point Note that the second pole is not dependent on the Ro of the devices
in the 2nd stage, but on the Gm of the 2nd stage and the load cap.
Hope this helps.
Vivek
zhonghan
china
Reply #2 - Jan 30th, 2006, 7:54pm
thanks for you interpretation, Vivek , you have solved part of my confusion .
I thought  the second pole Gm/Cload were deduced from small signal mode , so the total output resistence of the second stage could be gotten as 1/Gm no matter the frequency is high or  low . could you tell me what caused my error?
vivkr
Reply #3 - Feb 1st, 2006, 7:36am
Hi Zhonghan,
It is true that the second pole is derived from small-signal analysis. However, one assumes a priori that
the second pole is atleast beyond the unity-gain frequency of the opamp, preferably sufficiently away
to give good stability.
As the frequency lies beyond the unity-gain bandwidth (Gm1/Cc), the cap Cc is now acting like a short,
shorting the gate and drain of the second stage driver transistor (neglecting the Cgs of this device).
So, the impedance seen by the load cap Cl is Gm2/Cl which gives you the second pole.
I think you forgot that you were deriving the pole under these assumptions, and hence made the error
in assuming the second stage impedance to be too low.
Incidentally, the effect which causes this second pole is undesirable in many ways (poor PSRR).
If you were to use another architecture (Ahuja, JSS, Dec. 1983), the second pole would lie much
higher and this shorting effect would be gone.
If you can tolerate the extra current needed in the intermediate level-shifter of this scheme, and
don't mind the possibility of a small systematic offset, then I would recommend using it. It makes
life much simpler, especially compensation, and boosts your performance quite a lot.
Anyway, all that is unrelated to your question. I hope the confusion is cleared up now.
Vivek
zhonghan
china
Reply #4 - Feb 2nd, 2006, 2:49am
Hi Vivek ,thank you for your detailed explanation .
According to my understanding, you mean that the second pole is different when signal frequency changes. At low frequency , it is 1/(RII*Cload), and when frequency becomes sufficiently high, it would be a higher value ( Gm2/Cload ). If this change takes place after the first pole(Gm1/(Av*Cc) ) ,then  I think the low second pole may influence the frequency response.
  Do you think so ?
vivkr
Reply #5 - Feb 2nd, 2006, 4:19am
Hi Zhonghan,
I think my reply was not clear enough. The second pole is fixed. The pole location cannot depend on the frequency.
It is a characteristic of the system, otherwise the whole idea of linear systems would become unworkable.
What I meant was the following:
While computing the second pole, you always make an assumption that the opamp is reasonably well-designed,
which means that the second pole is expected to be a bit beyond the unity-gain frequency. Then, you compute the
location of this pole with this assumption. This allows you to simplify the circuit by assuming that the cap Cc
is effectively a short, and creates a drain-gate short at high freequencies, giving you the simple expression of
Gm2/Cl for the second pole.
Note that you can go ahead and derive the second pole location without this assumption, and you will get a number
very close to Gm2/Cl (detailed analysis can probably be found in Gray&Meyer or Johns&Martin).
It is not the pole location that changes with frequency, but the output impedance of the 2nd stage that does. So, it
is relatively high at low frequencies, giving you DC gain, and at high frequencies, it starts to roll off, causing the
gain to fall. However, since the 2nd pole must be beyond the unity-gain bandwidth, the effect of this rolloff will
not dominate the opamp's gain vs. frequency curve.
This is why the 2nd pole is called the "non-dominant pole".
Hope this helps.
Vivek
zhonghan
china
Reply #6 - Feb 2nd, 2006, 4:57am
This time you make me completely understand the issue. You are right , at low frequencies , the second pole is still Gm2/Cload not 1/(RII*Cload), and at high frequencies the rolling off of AC gain derives from two aspects. One  is the reducing of output resistence derived from shorting effect of Cap Cc , another is the shorting effect of Cap Cload .
Thank you again for your patience.
