What version of the IC tools are you running? Something strange is happening, because the version number returned by tdmcopier is bizarre...
Are you running in 64 bit mode (do you have CDS_AUTO_64BIT env var set)?
The usual solution to this is to run the "tdmupgrade" command to upgrade a project from a previous release - but not sure if your project was created in a previous version of the tools?
