Can you describe how the model libraries have been set up in ADE? Also, if you could post the top part of the netlist (input.scs) which includes the model files, that would help.
Which version of the gpdk are you using, and which version of the Cadence IC tools?
I can't see any reason why you should be having these problems; I can only assume something isn't set up correctly, but for that I'd need to know what you have done so far...
