Jul 20th, 2024, 9:29am
how to simulate the startup problem in bandgap ref (Read 916 times)
zychang
Ireland
Feb 05th, 2006, 12:43pm
a quick question on the startup problem in bandgap reference circuit.  I just found difficulties in simulating this issue. I  did ramp the supply voltage from zero in a dc sweep simulation, but it always gave me the same result either with or without startup circuit.  I don't know what else I have missed in the simulation configuration. any suggestions will be appreciated.
Mike
Paul
Switzerland
Re: how to simulate the startup problem in bandgap
Reply #1 - Feb 5th, 2006, 11:07pm
If you want to simulate the start-up behavior, you should try transient simulation. DC simulation only shows the sensitivity of the bandgap output to DC (or very low frequency) power supply variations, not the time-domain start-up.
You don't say what is the output when you do the DC sweep. It should look reasonable, at least when the start-up circuit is implemented.
Paul
zychang
Ireland
Reply #2 - Feb 6th, 2006, 6:55am
thanks for your comments Paul. Now i'm using the transient analysis to simulate the circuit. First, I disconnected the start-up circuit from the main circuit (by the way, the main circuit is a current reference generator using bipolar core) to see if the start-up problem shown up. But  the result shows that the output current jump to the current I want right away, and start-up didn't occur. I don't know what else I should do to it. looking forward to your comments again.
Paul
Switzerland
Reply #3 - Feb 7th, 2006, 4:09am
do you ramp the supply voltage? These circuits usually start up even without a dedicated start-up circuit, if you apply the full supply voltage at t=0 in your simulation, the operating point calculated by the simulator will usually correspond to this. Try starting your simulation with Vdd=0, then ramp it to its nominal value. Apply quite a fast ramp to see the start-up time of your circuit and not the rise time of your supply voltage.
You should also try to add a couple of estimated parasitic capacitances to the critical node, only then you should see a difference with/without the start-up circuit. As most of these circuits, when properly designed, start up by themselves based on leakage components, the goal of the start-up circuit is to make sure they do so over PVT variations, mismatch and so on, and also to do it in a convenient time.
Paul
