Paul,
I assume you meant to say that if you replace the switch-cap parts with equivalent resistors you can then simulate using an AC analysis not a PAC analysis.
If you have SpectreRF (as you say), you can then simulate using PSS/PAC with the circuit as is (I expect).
I'm sure it was just a typo, but just thought I'd check (with my pedant's hat on).
