Jul 20th, 2024, 11:40am
ac simulation of gain boost amplifiers (Read 2825 times)
Dennis Min
Feb 06th, 2006, 12:31am
hi, all
Attatched please find a high gain amplifier schematic with the gain boost scheme.
I wonder to know how to perform ac simulation of the pmos and nmos gain boost amplifiers, such as the gain vs frequency and phase margin.
Is the boost amplifier a transresistor opamp?
Tks.
zhonghan
china
Re: ac simulation of gain boost amplifiers
Reply #1 - Feb 6th, 2006, 6:32am
a  folded voltage omamp ?
vivkr
Reply #2 - Feb 7th, 2006, 3:34am
The simulation can be done the same way as for any other opamp. The simplest scheme however is to
leave the gain boost amps the way they are, and measure its AC performance in closed-loop.
Remember that the gain and phase of the amplifier (for the same load) remain the same whether it is tested
in closed loop or open loop. So, you can define gain as
VAC("out")/(VAC("inp")-VAC("/inm"))
The gain and phase of this quantity give you all the information you need.
As to the realization of the boost amp, it can be made using any conventional topology (common-source, differential pair,
folded-cascode etc.) depending on what kind of gain you want and other constraints.
Hope this helps.
Vivek
