dandelion
hi, I am designing a limiting amplifier for optical receivers. The input is 155Mbps 223 - 1 PRBS pattern. I want to know if can I use PSS+PHNOISE to analyisis its jitter characteristic?
If I use 0101..pattern, can I use PSS+PHNOISE to analyisis it? If so, first I get the phase noise and derive the jitter according the relationship between the phase noise and jitter. Can I do it?
