Aug 15th, 2024, 1:19am
help about input filter of adc (Read 1228 times)
jeffyan
Feb 07th, 2006, 3:33am
hi all,
what is the best bandwidth of a filter needed at the input of an ad converter if one desires to convert
a signal at a specific speed and with a certain number of bits?
thanks in advance.
jeff.yan
venky
Re: help about input filter of adc
Reply #1 - Feb 7th, 2006, 7:46pm
There are several aspects which determine the choice of input filter for adc. It depends on whether you have SHA in the ADC or not, your bondwire inductance, whether you are driving it with a amp or through a transformer, how linear is the ON time of SHA switch, and of course on the sampling capacitor. I 'm also trying to design one such filter.
  If you have SHA then the kick on the filter cap will be linear, otherwise the kick will be non-linear. The ON time of the sampling switch, (if it is a boosted switch) will also limit the linearity of the SHA's kick. If the series resistance that you put in the filter is very high then your transient settling might get affected. If the resistance is too small then circuit may start ringing because of bondwire inductance.
