Jul 19th, 2024, 11:28pm
what is the role of this capacitance? (Read 3436 times)
wjx197733
Feb 08th, 2006, 5:08pm
Hi, all: please look at this circuit. In this circuit, I think capacitance C2 is miller capacitance, but what is the role of the capacitance C1? How to confirm the value of C1?
Help me, please!!!
steven
Re: what is the role of this capacitance?
Reply #1 - Feb 8th, 2006, 6:31pm
Isn't it still a Miller cap? Because the stacked PMOS pair is cascoded with the NMOS pair. So the cap is connected from the output node to the previous stage.
Paul
Switzerland
Reply #2 - Feb 8th, 2006, 7:43pm
As Steven says, both are Miller capacitors. I have seen schematics using C2 in the past, but I haven't seen a circuit using both capacitors at the same time. Notice that both nodes don't have the same conductance, so the pole expression in presence of both capacitors may be somewhat different. Would be interesting if someone had time to write the equations...
Paul
steven
Reply #3 - Feb 8th, 2006, 8:15pm
Paul wrote on Feb 8th, 2006, 7:43pm:
Paul
Hi Paul,
I think the circuit would introduce zeros in the response. If considering the Thevenin impedance looking from the drains of M15 and M19, the impedance will be similar to common-gate topology. At high-frequency, the feedback network becomes inductative. I guess in this respect, either of them is redundant.
Steven
panditabupesh
Toronto
Reply #4 - Feb 11th, 2006, 9:48am
It is cascode compensation. Not sure why both, miller creates a zero (because of the feedforwad),  and cascode by eliminating the feedforward path is supposed to get rid of the zero.
-bp
