Aug 15th, 2024, 11:16am
Comparator resolution (Read 4854 times)
steven
Feb 08th, 2006, 6:46pm
I have a question on comparator's resolution. The comparator resolution is related to the offset voltage. Without offset compensation, the offset voltage is proportional to Vt variance and proportional to Vov. With offset compensation, the offset voltage can be further reduced. In both of these two cases, how to justify the comparator resolution due to fabrication process variances such as Vt? Or is it simply not possible without actual measurements?
Steven
huber
GO BEARS!
Los Angeles
Re: Comparator resolution
Reply #1 - Feb 10th, 2006, 8:53am
The main source of comparator offset is threshold voltage mismatch, but dynamic issues (such as mismatch in load capacitance) tend to result in larger offsets than you would expect.  There was a paper presented on Tuesday at ISSCC that implemented tunable load capacitance to compensate for comparator offset; very cool stuff.  If you have good mismatch data then you should be able to simulate comparator mismatch accurately.  Not sure what you mean by "how to justify the comparator resolution".
-Dan
steven
Reply #2 - Feb 17th, 2006, 12:25pm
huber wrote on Feb 10th, 2006, 8:53am:
-Dan
Hi Dan,
Ok, I see. When I said "how to justify the comparator resolution", I was thinking to justify the resolution analytically rather than simulation or measurement.
Thanks for clearing up.
Steven
sugar
Reply #3 - Feb 19th, 2006, 8:21pm
There was a paper presented on Tuesday at ISSCC that implemented tunable load capacitance to compensate for comparator offset; very cool stuff. -Dan
hi, huber
will you please tell me the title of the paper, I am really interested in it.
thanks in advance.
river
huber
GO BEARS!
Los Angeles
Reply #4 - Feb 20th, 2006, 10:26am
Hi river-
The paper was presented in Session 31: Very High Speed ADCs and DACs.  The title is "A 0.16pJ/Conversion-Step 2.5mW 1.25GS/s 4b ADC in a 90nm Digital CMOS Process".  The authors are G. Van der Plas, S. Decoutere, and S. Donnay.  Unfortunately I don't think the 2006 proceedings are online yet, so you'll either have to wait or find someone with a paper copy.  Basically they used a sense-amp-sytle latch loaded with banks of PMOS gate caps.  Each cap has a source/drain terminal that is controlled by a programming bit, which determines if the cap has an inversion layer or not.
-Dan
