Jul 19th, 2024, 1:19pm
THD of single ended amplfiers (Read 1834 times)
junga
Feb 14th, 2006, 12:08am
Hi, What is the best way to simulate THD of a single ended amplifier? The ampilifier is capacitively coupled to the input. I am choosing the maximum input level that is expected because it should result in maximum distortion. However, how can I select the fundamental?
Any tips?
Junga
uncle_ezra
Re: THD of single ended amplfiers
Reply #1 - Feb 14th, 2006, 2:03am
To simulate THD, just run transient and take the THD by using calculator (assuming you are using cadence). The fundamental frequency is based on the speed that your amplifier is expected to be running, so if the expected input frequency is 20MHz then use a sine source running at 20MHz.
Hope this helps !
