Jul 20th, 2024, 10:29pm
Composing input.scs with cmdline (spectre) (Read 6345 times)
chase.ng
penang/malaysia
Feb 14th, 2006, 5:43am
Anyone know how to compose spectre input.scs using command line? Other than clicking the green traffic light in the analog design environment GUI. I need to automate some for the simulations.
Thanks.
CHASE
Chase
View Profile chase.ng   IP Logged
bernd
Munich/Germany
Re: Composing input.scs with cmdline (spectre)
Reply #1 - Feb 14th, 2006, 6:09am
Maybe OCEAN (Open Command Environment for Analysis), will
be helpful for you.
Have a look at the online docs for the 'OCEAN Reference' guide.
Bernd
Just another lonesome cad guy
chase.ng
penang/malaysia
Reply #2 - Feb 17th, 2006, 4:39am
Apperantly OCEAN does not have anything that can create a netlist. Script written in OCEAN assumes that the netlist and input.scs already being composed.
Chase
bernd
Munich/Germany
Reply #3 - Feb 17th, 2006, 5:17am
I found these commands within 3 minutes in the OCEAN Reference manual.
simulator( 'spectre )
design( t_lib t_cell t_view )
createNetlist( ?display "nil" )
Tested them, and they do create a netlist!
Bernd
Reply #4 - Feb 18th, 2006, 6:25am
Bernd is quite correct. The only limitation is that you can't create a netlist from the ocean executable - but you can from DFII executables (e.g. icms. If you don't want it to be graphical, you can always use icms -nograph -restore myScript.ocn .
chase.ng
penang/malaysia
Reply #5 - Feb 22nd, 2006, 6:22am
Yeah, thanks a lot, that remind me that I did try out the createNetlist from ocean executable long long time ago but no netlist is created. I thought it cannot be used.
Chase
Chase
chase.ng
penang/malaysia
Reply #6 - Feb 27th, 2006, 12:14pm
It works, anyway, 1 more question, how can I change the directory the netlist being created?
chase
Chase
Reply #7 - Feb 28th, 2006, 7:41am
Use this at the beginning of your OCEAN script:
envSetVal("asimenv.startup" "projectDir" 'string  "/path/to/my/simRoot")
Note, it will still create the directory structure underneath that cellname/simulator/viewname/netlist as is used in ADE. Nothing you can do about that, sorry!
