schehrazi
University of CA, LA
This is how I set the pin properties when I simulate Verilog code with VerilogA or ... in a schematic. After choosing SpectreVerilog as the simulator, you can go to your schematic window, click on Mixed Signal->Inerface Element -> cell and then click on the cell that you want to set the properties for. A window will pop up which allows you to set pin properties. I hope this helps.
