steven
I read some differential Opamp designs. One of parameters is open-loop gain Av vs. output swing Vod, which could swing from negative to positive (symmetric to zero). I think the output swing should be symmetric to Vcm, the desired output common voltage which is not zero. How to simulate Av vs. Vod in the case? A sweeping Vcm vs. Av?
Thanks.
