Aug 16th, 2024, 1:25am
Number of Sidebands in PNoise (Read 2565 times)
schehrazi
University of CA, LA
Feb 19th, 2006, 11:08am
Does the number of sidebands in a PNoise simulation have to be smaller or equal to the number of sidebands in the accompanying PSS simulation?
Thank you for your help in advance.
-Saeed
Re: Number of Sidebands in PNoise
Reply #1 - Feb 19th, 2006, 10:30pm
In PSS you specify harmonics, in PNoise you specify sidebands. That being said, there is no relationship between the two. You specify what you are going to use, if you don't need to see them, you can set the number of harmonics computed by PSS to zero.
