Jul 18th, 2024, 3:33am
supply noise rejection for LC VCO (Read 2119 times)
boshiouke
trying to learn
Feb 20th, 2006, 11:00am
If the supply is the much noiser than the ground, which biasing scheme is better for a cross-coupled LC VCO? Biasing from bottom with NFET or from the top with PFET? Thank you.
Visjnoe
Re: supply noise rejection for LC VCO
Reply #1 - Apr 17th, 2006, 3:21am
if the supply is noisier than the ground, I think your better of with a PMOS (biasing) current source on top of the
cross-coupled pair. You can understand this by considering the 'limit' case where the PMOS current source acts as an ideal (SPICE) current source:
not disturbances coming from the supply can now enter your tank anymore!
Make sure to keep in mind the noise/PSRR of your VCO control voltage too!
Kind Regards
Peter
