MokoKoya
hello,
Good point, I can't find the download button either! here is my verilogA code and OCTAVE calculation.
// VerilogA for power, PWM_switch_3, veriloga
`include "constants.vams" `include "disciplines.vams"
module PWM_switch_3(c, a, p, cont, vin); inout c, a, p, cont, vin; electrical c, a, p, cont, n1, n2, n3, vin; parameter real R0 = 27; //output load parameter real VD = 800m; //diode voltage parameter real RL = 190m; //coil resistance parameter real Rdson = 500m; //transistor resistance parameter real IA = 700m; //output current parameter real Rcap = 500m; //ESR capacitor parameter real Rdiode = 10m; //diode resistance parameter real Rm = 0.0; //modulation resistance real IC, VAP; //internal DC parameters real VPA, IP, QB, QA, QC, D, Re, Rc; branch (n1, a) vcvs_1; branch (a, p) vccs_1; branch (n1, p) cccs_1; branch (n2, p) vcvs_2; branch (c, n2) Rs; analog begin @(initial_step) begin //DC operation point calculation VPA=IA*R0*2+6; IP=IA/(2*1.517) + 0.05; QA=Rdson*IP; QB=(VPA+IP*(RL-Rdson)); QC=(V(vin) -VPA-IP*RL-VD); VAP=-VPA; D=(-QB + (sqrt(QB*QB -4*QA*QC)))/ (2*QA); IC = IP / (1 - D); Re = (Rcap * VPA)/(Rcap*IP + VPA); Rc = Rm +/* (D*Rdson) + ((1-D)*Rdiode) + */(Re*D*(1-D)); if(analysis("dc"))begin V(vcvs_1) <+ 0.0; //n1, a I(vccs_1) <+ 0.0; //a, p I(cccs_1) <+ -IC * D; //n1, p V(vcvs_2) <+ VAP * D ; //n2, p V(Rs) <+ IC * Rc; //n3, c end end//initial_step
if (analysis("ac"))begin V(vcvs_1) <+ V(cont) * (VAP / D); //n1, a I(vccs_1) <+ V(cont) * -IC; //a, p I(cccs_1) <+ -I(Rs) * D; //n1, p V(vcvs_2) <+ V(cccs_1) * D ; //n2, p V(Rs) <+ I(Rs) * Rc; //n3, c end end
and the octave calculations
G0=Vin/(1-D)^2; G0dB=20*log10(G0) wz1=1/(RC*C); fz1=wz1/(2*pi); wz2=(R0*(1-D)^2 -RL)/L; fz2=wz2/(2*pi); w0=(1/(L*C)^(0.5))*( RL/R0 + (1-D)^2)^(0.5); f0=w0/(2*pi) Q=w0/(RL/L + 1/(C*(R0+RC))); Gvd=G0*(1+s/wz1).*(1-s/wz2)./(1+(s/(w0*Q))+((s.^2)/(w0^2)));
The circuit I place the model into is a boost converter (open loop), with V(cont) input being an AC source representing the small signal varience of the duty cycle.
Thank you, Andrew
