Jul 22nd, 2024, 7:21pm
the right power supply equipment for analog chip (Read 107 times)
chu
Mar 08th, 2006, 2:22am
hi all,
i'm choosing a POWER SUPPLY equipment for test and measurement on ANALOG CHIP. please give me some advise on the SPEC, thx in advance.
1) what is the max ripple & noise acceptable for analog chip ? 5mV rms & 3mA rms ? 10mV ptp ? or ?
2) line regulation constant voltage & current ? 0.01% 3mV & 0.2% 2mA ? or ?
3) load regulatin constant voltage & current ? 0.01% 3mV & 0.2% 2mA ? or ?
thank u so much.
Paul
Switzerland
Re: the right power supply equipment for analog ch
Reply #1 - Mar 8th, 2006, 12:23pm
without knowing your design it is hard to specify its power supply. Ripple requirements depend on your circuit's PSRR (power supply rejection ratio) and its frequency dependency. Power supply definition also depends on the current consumption of your chip.
Notice that most commercial power supplies are switched power supplies, which usually exhibit ripple at a particular frequency (switching frequency). For low ripple, you should use a low drop-out regulator (LDO) between the switched supply and your chip.
You can certainly find a lot of useful information in the appnotes of commercial LDO vendors (Analog Devices, Linear Technology, Maxim and many others I may forget).
I hope this helps a little
Paul
