Jul 19th, 2024, 3:16am
what's the difference between biasing and referenc (Read 3597 times)
jjsnail
Mar 09th, 2006, 2:37am
hi all
i know that the biasing circuit is used for biasing a transistor to afford stable current and reference for stable voltage .and the bias voltage is often generated by reference circuit so the biasing current is PTAT.
why use PTAT current for bisaing?what about the zero TC current?
ACWWong
Oxford, UK
Re: what's the difference between biasing and refe
Reply #1 - Mar 9th, 2006, 2:54am
depends on the circuit to be biased and the fact that PTAT (current related to Vt (=kT/q)) is easy to generate.
for example high speed Source-Coupled logic dividers would benefit from more current at high temperature to maintain divider speed/operation so PTAT bias may be better here than zero TC current.
so it is "horses for courses" ... the designer using the bias characteristic that suits their circuit, be it PTAT, CTAT or somewhere inbetween.
jjsnail
Reply #2 - Mar 10th, 2006, 3:25am
thanks,ACWWong.
Let's talk about an OPA circuit.the zero TC biasing means the gain is stable when the temperature changes,right?
how can we generate a Zero TC biasing ciruit?do we have to copy and sum up the complementary current in the bandgap ref to get it?
ACWWong
Oxford, UK
Reply #3 - Mar 10th, 2006, 9:40am
Well again it depends on the OPA and the configuration under consideration.
Quantities like gm have tmeprature characteristics which can be compensated for by appropriate bias.
So in the design of an opamp, one may well start with zeroTC bias and then sweep over temperature to see if the varitaion of the relevant opamp performance parameters are acceptable before considering improvements thorugh bias charactersitic tweaking.
yes zeroTC biasing is a combination of PTAT and CTAT quanties. if you comibine in different ratios you can make any temperture coeffient inbetween as well, not just zeroTC (although zeroTC is usually the target)
For good treatment of this subject have alook at Grey & Meyer "analysis and design of analog integrated circuits" or similar.
jjsnail
Reply #4 - Mar 10th, 2006, 10:07pm
thank u:) Wink
