Aug 16th, 2024, 1:03pm
has BSIM4 been incorporated into Cadence yet? (Read 5292 times)
kokabanga
Mar 10th, 2006, 12:12am
I am trying to find out which version of analog artist has the ability to recognize BSIM4 modle files.
Does anyone know about this?
Thank you very much
Naren
naren
bernd
Munich/Germany
Re: has BSIM4 been incorporated into Cadence yet?
Reply #1 - Mar 10th, 2006, 2:09am
Find out yourself
spectre -W
spectre -help bsim4
Bernd
Just another lonesome cad guy
Reply #2 - Mar 15th, 2006, 5:22am
BSIM4.2.1 was in Spectre 4.4.6 years ago.  If you need a later BSIM4 (Berkeley is on 4.5), you'll need a newer version of Spectre.
kokabanga
Reply #3 - Mar 15th, 2006, 11:50pm
I think the version of SpectreRF is 4.4.6.
I typed in "spectre -W" and I get "sub-version 4.4.6.061301"
"spectre -help bsim4" gives "No such analysis, device etc etc.....".......there is no Bsim4...highest is bsim v3.3.2.
please help.
naren
bernd
Munich/Germany
Reply #4 - Mar 16th, 2006, 1:11am
sub-version 4.4.6.061301 is equal to Cadence DFII 4.4.6 QSR2
and it is pretty old (June 2001) and you're right bism4 is not supported in this
release.
Can you update? The higher version the better it would be.
If you are on a University program and you don't have access to
the latest DFII version, you should update at least to
Cadence DFII 4.4.6 MSR10 == sub-version  4.4.6.031103 (March 2003).
This version supports bsim4 version 2.1, which is not the newest, but
might help you.
Bernd
kokabanga
Reply #5 - Mar 16th, 2006, 9:25pm
I am trying to find out how an LNA using a 65nm process works.
I have the model files for such nm process from
http://rfic.eecs.berkeley.edu/~niknejad/ee142/pdf/models65.lib
However, I do not have the required version of spectre to try these out.
I am unable to upgrade either!
guess I am handicapped eh!
naren
Reply #6 - Mar 17th, 2006, 5:15am
That's an odd set of models -- no STI stress parameters, no well-proximity effect, ...  and the version is 4.0.
I don't think this really corresponds particularly well to an actual 65nm process.  Do you have a netlist built for this specific model library?  If not, the LNA is probably not biased correctly because it will have been designed using other models. Are you trying to understand how a generic LNA works?  In which case you should look for bsim3 models for an older technology.
