That's an odd set of models -- no STI stress parameters, no well-proximity effect, ... and the version is 4.0.
I don't think this really corresponds particularly well to an actual 65nm process. Do you have a netlist built for this specific model library? If not, the LNA is probably not biased correctly because it will have been designed using other models. Are you trying to understand how a generic LNA works? In which case you should look for bsim3 models for an older technology.
