Jul 17th, 2024, 11:40pm
specfications for transmission lines in spectre (Read 10989 times)
ramana_akula
Mar 16th, 2006, 3:45am
Hi All.. This is Ramana, can u guys,help me out..
                      i need to use Tx Line with following specs
 for a small length ∇ deltax, i know R, L,C,G & Rs(for skin effect) & Rd( for Dielectric loss).. then i don't know hw to use these things in spectre format..
   i mean, i was unable to calculate Z0, vel, f & electric length.. if i use formulae  for Z0= sqrt( (R+jwL)/(G+jwC) ) it will have complex part,
  Plz help me...
Thanks alot..
Ramana Akula
Online
Re: specfications for transmission lines in spectr
Reply #1 - Mar 16th, 2006, 8:16am
You specify z0 and electrical length for the lossless case (set both R and G to 0). Then you add the loss back in using g, dcr, and corner. See "spectre -h tline" for the details.
ramana_akula
Reply #2 - Mar 19th, 2006, 9:45pm
Hi Ken... Thanks alot for ur info. can U make sure the following specs in spice & spectre are equal & help me in these specfications..
In SPICE:-R, L, G, C, Rs, Gd & Physical Length of Tx Line are known. ( need to change into spectre format)
For Spectre:-     (1) Z0, vel are calculated using L & C(Loss less)
                          (2) len is same as physical length.
                          (3) dcr is same as R in Spice
                          (4) corner ??? ( help me here, hw to calculate in terms of above spice specs)
                          (5) g is same as G in Spice.
                          (6) hw to include Gd in Spectre ( like (alphad) or (fd & qd) specfication ????? )
     Please Help me..
Thanks Ken...
Ramana Akula...
Online
Reply #3 - Mar 20th, 2006, 11:30am
I am unfamiliar the Spice parameters you speak about. From my experience, Spice does not support loss in transmission lines. Of course that experience comes from a long time ago. Some people refer to HSpice as Spice. Are these HSpice parameters?
Spectre models two types of conductor loss. There is the DC resistance (dcr) and there is the skin effect. The skin effect can be specified in different ways. You can either give a resistance at a frequency (fc) or you can give the dc resistance and the corner frequency. If you give the resistance at a frequency, you can give the resistance in several ways, as a resistance (r) or using alphac or qc.
Spectre models one type of dielectric loss, which can also be given as a conductance (g) or as alphad or qd.
I'm afraid I have no idea why the Spice you have has two conductance terms.
ramana_akula
Reply #4 - Mar 20th, 2006, 8:41pm
Hi Ken.. Thanks for ur reply...  i was well understood what u said...
         (1) I'm using smart spice(SSpice) not HSpice..
         (2) the two conductances in spice are G (corresponds to parallel resistor in tx.model)  & Gd(corresponds to dielectric loss )
        in My SSpice deck, Tx. Line statement is
 W3 in1 in2  gnd out1 out2 gnd RLGCFILE=TLDATA.RLC  L=1
The file TLDATA.RLC will have values for R L G C Rs Gd parameters.see attachment.
 what i exactly need is corner frequency & alphad calculations..(Tx Line described in spice format i mean above spice statement & .RLC file)
Thanks Ken...
Ramana Akula..
The TLDATA.RLC file is:-
________________________________ file starts ___________________________________________
* RLGC parameters for two signal conductor
* lossy transmission line
* N - number of signal conductors
2  1
* 1 - Frequency
250E6
* L - indictance (nH/m)
613n
0.0   613n
* C - capasitance (pF/m)
56p
0.0   56p
* R - resistance (Ohm/m)
98e-3
0.0     98e-3
* G - DC conductance
0.1e-12
0.0   0.1e-12
* Rs - Skin-effect resistance matrix per unit length
0.29e-3
0        0.29e-3
* Gd - Dielectric-loss conductance matrix per unit length
0.1e-3
0      0.1e-3
_____________________________ file Ends ______________________________
Online
Reply #5 - Mar 20th, 2006, 10:18pm
I still don't understand the difference between G and Gd. They seem like the same thing to me.
If you need the details of the corner frequency and the alphad calculations, you should take a look at either the Spectre manual or "spectre -h tline".
Reply #6 - Mar 22nd, 2006, 9:48pm
What you are after is "mtline" (see spectre -h mtline). This is a multi-line transmission line, which allows specification of RLGC matrices, and also has (in MMSIM60) a field solver built-in to generate the RLGC matrices from physical dimensions. It's similar to the W element in hspice and smartspice.
ramana_akula
Reply #7 - Mar 23rd, 2006, 10:31pm
HI Andrew.. Thx for ur reply..
 i used mtline to specify RLGC matrices. but results with spectre are not at all compareable with spice.
i had  given sine voltage source with freq=1M & ampl=10
my spectre deck is : ( for testing..)
___________________ spectre file starts  ___________________
simulator lang=spectre insensitive=yes
//                              OPTIONS STATEMENT
simulatorOptions options reltol=1e-5 vabstol=1e-6 iabstol=1e-12 temp=25 \
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="sens.output"
vvin1 (in1 gnd)  vsource type=sine mag=10 ampl=10 freq=1M dc=0
vvin2 (in2 gnd)  vsource type=sine mag=10 ampl=10 freq=1M dc=0
vgnd (gnd 0)  vsource dc=0
TL1 (in1 out1 in2 out2 gnd gnd) mtline len=100
+ r= [ 98e-3 +     0.0     98e-3]
+ l = [ 613n+      0.0   613n]
+ g= [ 0.1e-12  +        0.0   0.1e-12]
+ c= [ 56p+      0.0   56p]
+ rskin= [ 0.29e-3 +             0    0.29e-3]
+ gdloss= [0.1e-3+          0    0.1e-3]
//rin1 (vin1 in) resistor r=50
//rin2 (vin2 in) resistor r=50
rout1 (out1 0) resistor r=50
rout2 (out2 0) resistor r=50
//                                 ANALYSIS
//analysis_ac1 ac dec=1000 start=1 stop=1G save=all oppoint=rawfile
tran1 tran step=1f stop=10m
// save=all oppoint=rawfile
_________________ spectre file ends _______________________
my spice file is: (for testing..)
_________________ spice file starts _______________________
* Tx. Line
.options scale=1 accurate=1 rmax=1 RAWPTS=100 NUMDGT=16 probe expert
.temp 25
.save all
VINP1 IN1 gnd AC  SIN (0 10 1Meg)
VINP2 IN2 gnd AC  SIN (0 10 1Meg)
RO1 OUT1 gnd 50
RO2 OUT2 gnd 50
W1 IN1 IN2 gnd OUT1 OUT2 gnd RLGCFILE=TLDATA.RLC L=100
.TRAN 1N 100U
___________________ spice file ends _____________________
the RLGC file(TLDATA.RLC is in my previous mail)...  i'm also attaching results..
from hand calculations i sud get time delay as 0.58usec,8V(appx).  I got this dealy in both cases. but the attenuation is more in spectre,
i got   0.589usec delayed sine wave with 7V ampl & 1MHz freq ( for smart spice) &
          0.582usec delayed sine wave with 0.118mV & 1MHz freq, but it has DC value of              0.118mV/2 = 0.059mV i mean it was clamped to +ve values. ( very abnormal)
      Plz Help me, hw to get correct results with spectre..
Thanks Andrew & ken..
Ramana..
ramana_akula
Reply #8 - Mar 23rd, 2006, 10:47pm
spice result is:
MichaelTian
Reply #9 - Mar 27th, 2006, 7:57am
Ramana,
It seems you may have a bad gdloss parameter in the testcase. The regular constant g is 0.1e-12 /Ohm, while the gdloss is 0.1e-3 1/Ohm. Recall the formula: G(f) = G_dc + f * gdloss, this leads to a huge G(f) at 1M Hz, which should attenuate the signal to near zero. So Spectre
is actually correct, as out1 is near zero.
To probe this a little bit further. add the following analysis line into your Spectre netlist:
ac1 ac start=1K stop=1G dec=20
Look at in1/out1 at 1MHz, you will see that out1 is zero.
Then you can comment out this gdloss parameter, re-run the simulation, you should see ac/tran results at out1 corresponding to each other
around +/- 5V.
Mike
ramana_akula
Reply #10 - Apr 5th, 2006, 2:56am
Thanks Andrew & Mike..
         i got the reason( i think)...  we need careful look at units of spice & spectre.
For  Rskin ->  ohm / m                         for  spice
                         ohm / ( m * sqrt(Hz) ) for spectre
For  gdloss ->  mho / m                         for  spice
                         mho/ ( m *Hz )              for spectre
so if we take care this one we can get gud comparable results spice & spectre...
but i'm getting pblms when pulse is given as input..
 * If the time period of pulse is high enough, i mean usec's it'z giving gud results.  if the period is in the order of nano sec(10-20ns) it's giving abnormal response
My deck is:
-------------------------------------------- Deck starts -----------------------
// A simple Tx line terminated by 50ohm load with pulse input
// *********** Input Signals....
// ***** sine
//vvin1 (in1 gnd)  vsource type=sine mag=10 ampl=10 freq=1M dc=0
//vvin2 (in2 gnd)  vsource type=sine mag=10 ampl=10 freq=1M dc=0
// ***** Unit Step
//vvin1 (in1 gnd)  vsource type=pwl wave=[0n 0 100n 0 110n 10 10m 10 10.00001m 0]
//vvin2 (in2 gnd)  vsource type=pwl wave=[0n 0 100n 0 110n 10 10m 10 10.00001m 0]
// ***** Pulse
//vvin1 (in1 gnd)  vsource type=pulse val0=0 val1=10 rise=5u fall=5u delay=0 width=10u period=30u                //working..
//vvin2 (in2 gnd)  vsource type=pulse val0=0 val1=10 rise=5u fall=5u delay=0 width=10u period=20u               //it's working...
vvin1 (in1 gnd)  vsource type=pulse val0=0 val1=10 rise=1n fall=1n
+ width=8n  period=16n  //it's not working...
vvin2 (in2 gnd)  vsource type=pulse val0=0 val1=10 rise=100n fall=100n delay=0 width=10u period=20u        //it's working...
vvin (in gnd)  vsource type=pulse val0=0 val1=10 rise=1n fall=1n
TL_mtline (in out gnd ) mtline len=100
+r= [ 98e-3 ]
+ l = [ 613n ]
+ g= [ 0.1e-12 ]
+c= [ 56p]
+ rskin= [ 0.1834e-6 ]
+ gdloss= [0.4e-12 ]
+ rskin= [ 0.1834e-6 +             0    0.1834e-6]
+ gdloss= [0.4e-12+          0    0.4e-12]
rout (out 0) resistor r=50
//                                 ANALYSIS
tran1 tran step=1p stop=10m
----------------- deck ends --------------------
 i'm also attaching the results. plz tell me the reason for abnormal response ( does reflections from load making the difference?????)
  AC response is also not gud.. i'm tring this for 100m category 5(CAT 5) UTP cable
Thanks to All,
Ramana...
ramana_akula
Reply #11 - Apr 5th, 2006, 2:58am
AC Response is attached...
ramana_akula
Reply #12 - Apr 10th, 2006, 4:19am
Hi.. can u plz help me...
  tx.line AC response has some glicthes.. can u plz tell me the reason.
i'm attaching my deck & AC response plot.
-------------- File --------
* Tx. Line
.temp 25
.save all
*------- INPUT'S...
*** Sine
VINP1 IN1 gnd ac=1
VINP2 IN2 gnd ac=1
RO1 OUT1 gnd 50
RO2 OUT2 gnd 50
W1 IN1  gnd OUT1  gnd RLGCFILE=TLDATA.RLC L=100
W2 IN2  gnd OUT2  gnd RLGCFILE=TLDATA.RLC L=1
.ac dec 100 0.1 1G
----------------- file ends --------------
TLDATA.RLC file :
----------------- .RLC file starts -----------------
1 1
* 1 - Frequency
250E6
613n
56p
0.98e-3
0.1e-12
0.29e-3
0.1e-3
---------- .RLC file ends  -----------------
 these are cat5 UTP cable specfications, i came across that freq response has shape of  decying exponential curve, but i'm getting Low pass filter curve.
can u plz provide me some info. regarding this..
                         waiting for ur positive response...
Thanks Alot ,
Ramana Akula
