Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 17
th
, 2024, 7:30pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› IIP3 calculation
Previous topic
Next topic
IIP3 calculation (Read 4424 times)
ssk_288
Miles to Go
Bangalore
IIP3 calculation
Mar 17
th
, 2006, 9:29pm
For fast IIP3 calculation of LNA - Mixer pair, I am feeding a 2 tone signal with 3 MHz difference between them. Then I do the PSS analysis and find the IIP3 using the formuls given in the
http://www.designers-guide.org/Analysis/intercept-point.pdf
Now
To calculate the IIP3 do I use the db20 or dbm function in cadence?
IP Logged
RFenthusiast
Re: IIP3 calculation
Reply #1 -
Mar 26
th
, 2006, 10:01pm
Usually the IIP3 is plotted in dBm so you know what the IIP3 is wrt input power. So if you want the IIP3 in terms of power then you could use the dBm option.
Regards.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
