Jul 21st, 2024, 7:17pm
Simulating switched-capacitor filter in spectreRF. (Read 3800 times)
Raul
San Jose, CA.
Mar 19th, 2006, 10:04pm
 I have read and run the netlists included on the article posted in this website; "Simulating switched-capacitor filters with SpectreRF". But I really want to use the schematic editor instead of running the netlist in the command line. I've found one problem though; the vsource component doesn't allow me to define two frequencies in the symbol from the analogLib. This corresponds to the line in the netlist that implements the input source "Vin" on the first netlist tah.ckt. Can anyone help me figure out what's wrong?
regards, Raul Perez
Re: Simulating switched-capacitor filter in spectr
Reply #1 - Mar 22nd, 2006, 10:56pm
Really? Are you using the analogLib/vsource/symbol component? If so, then set "Source Type" to "sine", and then uncheck the checkbox labelled "Display second sinusoid" and fill in the parameters for it there.
I was wondering if you were perhaps using the older "vsin" component, but even that has parameters for the second frequency (called Amplitude 2, Frequency 2, for example). This still is netlisted as a spectre vsource component - it's kept for compatibility reasons - I'd use vsource these days though, as it's a more direct interface to the underlying spectre source.
Raul
San Jose, CA.
Reply #2 - Mar 22nd, 2006, 11:13pm
i had not seen the box to select the second sinusoid. thanks a lot.
regards, Raul Perez
xwcwc1234
TAIWAN
Reply #3 - Apr 18th, 2006, 12:33am
I need to simulating noise performance of a chopping amplifier . Anyone know how to simulate it using SpectreRF ?
Reply #4 - Apr 23rd, 2006, 9:29am
Choppers are very much like switched-cap filters, so you can use the same paper as a reference (http://www.designers-guide.org/Analysis/sc-filters.pdf).
