Really? Are you using the analogLib/vsource/symbol component? If so, then set "Source Type" to "sine", and then uncheck the checkbox labelled "Display second sinusoid" and fill in the parameters for it there.
I was wondering if you were perhaps using the older "vsin" component, but even that has parameters for the second frequency (called Amplitude 2, Frequency 2, for example). This still is netlisted as a spectre vsource component - it's kept for compatibility reasons - I'd use vsource these days though, as it's a more direct interface to the underlying spectre source.
