Jul 20th, 2024, 1:24am
substrate current effect? (Read 2683 times)
jaylin79
Mar 20th, 2006, 5:10pm
Hi Guys,
I am designing a bipolar circuit, its input is +/- 20V, and there is a problem that when the collector of NPN is lower than -0.7V, there will be substrate current flowing from P-sub to N collector, will this current give a bad effect to the whole circuit if we don''t consider the power dissipation effect.
Best regards
Jay
Jay
RobG
Bozeman, MT
Re: substrate current effect?
Reply #1 - Mar 20th, 2006, 7:44pm
I dunno, do you consider latching up a bad effect? ;).  Seriously, if you forward bias the collector base of an NPN you don't just turn on a diode... you (generally) turn on the parasitic pnp that goes along with it (PNP = p+ base/N- Collector/Substrate).  This pnp often isn't modeled.  Yes, the effect can be quite bad, and if the substrate currents are large enough they might even turn on a npn and you'll latch everything up.  You really don't want to forward bias the BC of a bipolar.
jaylin79
Reply #2 - Mar 20th, 2006, 9:03pm
RobG, thanks a lot!
Jay
judean1
Reply #3 - Mar 21st, 2006, 2:48am
Making the collector base junction forward bias will effectively take away the very essence of the bipolar circuit as an active device.
V
