Jul 20th, 2024, 9:31am
rapid poweron opamps (Read 2022 times)
vivkr
Mar 22nd, 2006, 1:57am
I am wondering if there is a good way to turn on a high-gain opamp (DC gain ~ 90 dB) from
a standby condition to fully accurate operation mode (fully loaded) in a short duration
(~100ns).
Any ideas will be appreciated? I am interested in using the opamp in a circuit which works
in burst-mode, and is usually turned off or placed in standby to save power.
Vivek
Paul
Switzerland
Re: rapid poweron opamps
Reply #1 - Mar 23rd, 2006, 12:44pm
Hi Vivek,
100ns seems quite short for complete wake-up, but you may find some interesting ideas in the domain of switched op-amp circuits introduced by Crols and Steyaert (that's at least my earliest reference). In this technique, some switches in switched-capacitor circuits are moved inside the amplifier, which output is switched to high impedance in one clock period. It may be worth having a look at the following paper:
Switched-opamp: an approach to realize full CMOS switched-capacitor circuits at very low power supply voltages
Crols, J.; Steyaert, M.;
IEEE Journal of Solid-State Circuits
Volume 29,  Issue 8,  Aug. 1994 Page(s):936 - 942
Paul
