Jess Chen
fran2k5,
You are right about the window size and the overlapping segments. But the overlapping segments are selected from the total time record. The total time record consists of uniformly sampled time points and the total number of points is specified by the "Number of Samples" parameter. Spectre does not generate uniform time steps by default. However, the Fourier analysis in the psd function requires uniform samples. The Number of Samples determines how many uniformly sampled points to interpolate from the complete (non-uniformly sampled) record for use with the overlapping segments. The window width determines the frequency resolution. The Number of Samples, together with the start and stop times, determines the sampling period, which in turn determines the maximum frequency of the psd analysis.
-Jess
