Paul
are you using subcircuits for all devices in Eldo. If you are using model cards, the Monte-Carlo is not performed correctly, because the same parameter variations are applied to all devices with identical dimensions. Indeed, Eldo does not know "inline subcircuit" statements. In your case, does Spectre give larger spread than Eldo? This would be a hint on the fact that the Eldo computation is not correct.
Paul
