Jul 16th, 2024, 11:51am
Verilog simulation: Can't descend into cell views (Read 1909 times)
aprior
Apr 6th, 2006, 4:05pm
I am having a problem trying to simulate with a verilog-a file.  My steps where:
1. File->New->Create  VIEW Name: veriloga  TOOL: VerilogA-Editor
2. File->New->Create  VIEW Name: symbol   TOOL: Composer-Symbol
I edited the veriloga.va file and matched up the veriloga and symbol pins.  The syntax seems to be okay.
I created a Hierachy as follows:
Library list: ap_sim ap_lib
View List: spectre cmos_sch schematic veriloga ahdl
Stop List: spectre veriloga
The schematic simulates just fine until I use the hierachy editor to switch in a verilog view. After clicking Netlist and Run I get the error:
ERROR: Netlister: unable to descend into any of the views defined in the view list: "veriloga" for instance I14 in cell SigmaDelta_sim. Either add one of these views to: Library: ap_lib Cell: firstorder_sigmadelta or modify the view list to contain an existing view.
I have another verilog file form an old employee that I copied into my lib.  Removing my verilog symbol and placing in the that symbol causes no problem.
My Setup simulator/dir/Host simulator is "Spectre"
Note:  I get the same problem if I remove a pin from the verilog code and symbol of the old cell.  It as if I need to compile / update the cell somehow.
Help Please
« Last Edit: Apr 06th, 2006, 5:57pm by aprior »
ACWWong
Oxford, UK
Re: Verilog simulation: Can't descend into cell vi
Reply #1 - Apr 7th, 2006, 9:04am
after step 1) and you close the veriloga editor (and pass the parser) it should have automatically asked you to create the symbol. I think your problem may stem from the veriloga and symbol cdf's aren't synchronised properly.
try from the test bench schematic -> Design-> create view -> from cellview.
then fill in the form so it points to your veriloga view, and to view being symbol.
when you click ok, it will ask you to overwrite or modify your existing symbol, either will do the job.
hope this helps ....
aprior
Reply #2 - Apr 7th, 2006, 10:38am
The VI editor normally comes up, but I use another editor, that doesn't give me an indication that it passed the parser.  I am now using the VI editor for all changes.  I now get the passed syntax (parser) check message.  Everything seems to be working fine now.
Thanks for the help
bernd
Munich/Germany
Reply #3 - Apr 7th, 2006, 11:08am
Strange, strange, I thought I would be related to the switch or stop view list,
but if the issue is solved when the parser gets invoked  fine.
You can define your preferred editor with the variable
editor = "yourEditor"
e.g.
editor = "emacs"
or
editor = "nedit"
either direct in the Command Interpreter Window input line
or in your local .cdsinit file. Then the parser gets also invoked,
if you open the  VerilogA view over the Library Manager.
Bernd
Just another lonesome cad guy
Reply #4 - Apr 11th, 2006, 10:01pm
Yes, the parser is invoked to ensure that the "cdb" file (or "oa" file if using OpenAccess) is created for the verilog-a view. This contains information about the terminals and directions, and allows the netlister to view switch into the verilog-a view. Editing the file outside of DFII doesn't create this additional file in the cellView, and so it doesn't know how to switch into the verilog-a view.
As Bernd said, editing from within DFII will trigger the parser when the editor exits.
jbdavid
Reply #5 - Apr 21st, 2006, 1:58am
Actually it will invoke the parse if the timestamp on the file is different after exiting the editor than it was before..
this is ALWAYS the case for vi if you :wq or :zz to exit..
but if you use nedit, open the file, click save, and exit it will NOT invoke the parser, because you didn't change the file,
so even if you ASK it to save.. it knows you have made no changes, and won't change the timestamp..
so you have to ACTUALLY add a space in a comment or something and THEN save to invoke the parser..
(or "touch" the file after you opened it.. )
When I create verilog-A from a perl script I copy it into the cell view, then set
editor = "touch" and "open" the files.. which "just" calls the parser (don't say yes if there are syntax errors!)
to build the extra stuff needed..
(then I set editor ="nedit" again.. )
there are Verilog-A pattern files (several years old) on the nedit web site at www.nedit.org .. still waiting for someone to contribute a similar set for SKILL and Verilog-A for VIM...
Nedit has a nice "incremental search bar" and gui driven search and destroy .. er replace..
and it has been my personal workhorse for the last 5+ years..
Jonathan
jbdavid
