Jul 21st, 2024, 1:28am
Spice model explanation needed!! ^^ (Read 1323 times)
ee484
Apr 7th, 2006, 7:17am
Hi, all,
I have questions about Cdb and Cjd.
If my understanding is correct, in saturation, Cjd is roughly Cdb.
(Cjd = drain-bulk junction capacitance (drain bottom plate and sidewall capacitance, Cdb = dQd/dVb - transconductance)
In spectre op values, Cjd and Cdb are different in saturation region. Do you guys know why? (Cjd is several order bigger than Cdb)
I believe that Cdb in op values in spectre is in F, not F/m^2..or so.
Since Cdb is defined as dQd/dVb, it is small signal capacitance. What about Cjd?
Is it small signal capacitance too? (I named small-signal capacitance, do you have better name and explanation? - Is it capacitance load at the drain while it is being biased?)
If I want to account drain load capacitance of a transistor, do I have to consider Cdb or Cjd?
(Bottom line: How does Cdb we see in analog books differ from Cdb in spice?)
Thanks in advance!!
PS: Any references are welcome!! (Easy to read ones..^^)
« Last Edit: Apr 07th, 2006, 10:03am by ee484 »
