Jul 17th, 2024, 12:29pm
current measurement in hspice ---issue (Read 2310 times)
curious
Apr 07th, 2006, 6:53pm
Hello all,
I was measuring the current through a source. So when the current is flowing in to the souce it should plot positive current but it plots the current is negative.
I am attaching the circuit which I am talking about.
Please let me know what the problem is?
Thank you,
c
Re: current measurement in hspice ---issue
Reply #1 - Apr 25th, 2006, 5:46am
You might want to check your Hspice manual on sign conventions.  Eg, I recall that current into a MOS drain is positive, but current *out* of the source is positive.
