vivkr
Hi Sheldon,
It is not quite clear what dark current you got? 0.25V/ms ??? doesn't read like a current.
By the way, what temperature are you doing the measurement at? What parameters do you need to provide in your diode definition?
I once had a problem when using some diodes as the area was set to a very large value by default in the model. This was set to 100u (m^2) instead of 100p (m^2) for a 10u x 10u device by someone who created the model in question and put all parameters in 'u' as default. I hope you don't have the same issue.
Regards Vivek
