Aug 15th, 2024, 3:47am
How to do line-manuplating after read in data file (Read 3268 times)
yaxazaa
Apr 15th, 2006, 12:09pm
My question is how I do line by line manuplation in Verilog-A after I read in a data file contains two columns. For example: data file name is data.dat contains:
1 10
2 20
3 30
etc;
in Verilog-A:
integrer infile;
real x[0:100], y[0:100]
real z[0:100];
infile = $fopen("$path/data.dat");
Then What I am going to do is to assign column one as x, column two as y, and z = pow(y,x/20). HOw should I do it? Can someone help?
Thanks.
jbdavid
Re: How to do line-manuplating after read in data
Reply #1 - Apr 15th, 2006, 3:50pm
for details look at $fread $fscanf functions.. you may want to refer to Verilog-2004 manual (or Verilog-AMS 2.2 )
manual for all the details on reading files..
Jonathan
jbdavid
Reply #2 - Apr 25th, 2006, 5:37am
It looks like the data file might be formatted in a way that $table_model would work.  This was added in LRM 2.2, but was already available in some simulators.  Check your simulator documentation.
