jbdavid
with IC5141 there is a library called bmslib it has a few verilog-a models in it.. a helpful one in thls case is busset8 - to show you how to take integer -> 8 bits out.. (thats tested and what folowes isn't . what you want to do is read the integer from the file then set 14 outputs based on that integer..
module file2source (out, clk, gnd); output [13:0] out; electrical [13:0] out; input clk; electrical clk; inout gnd; electrical gnd;
parameter vhi = 1.5; parameter vlo = 0; parameter tr = 20p; parameter tf = 20p; integer vd[26:0]; // number of samples to read from the file if doing it all at once? integer vd; // holds the entire integer value if reading from the file until its empty integer infile;
analog begin @(initial_step) begin infile = $fopen("file.dat", "r"); $fscanf(infile, "%d", vd); // only reading 1 integer (integer has 32 bits) end @(cross(V(clk,gnd)-0.5*Vhi, 1)) begin // posedge $fscanf(infile, "%d", vd); // only reading 1 integer (integer has 32 bits) // what if EOF? end generate i (13, 0) begin V(out[i],gnd) <+ transition((vd & 1<<i)?vhi: vlo, 0, tr, tf); end
// note this form of generate statement is deprecated syntax.. but still works in 5141.. and mmsim6.. there is a newer form of the syntax in the AMS2.0 LRM, but last time I tried that I think it didn't work in 5.0.33 (now in EOL - but I still have to support it for a while yet.. so I'm waiting a little longer before going to the new syntax.. you may be luckier..
------------------------------- OR you could run spectreVerilog OR you could run AMS designer, and write your DAC to use Logic input values (some examples of that in bmslib too.. but AMSD takes 3 tokens..
G'luck! jbd
