Aug 17th, 2024, 5:23am
text file for DAC input~ (Read 5971 times)
YiLi
Apr 17th, 2006, 11:50pm
I am new to here, and I am doing some analog and mix-mode design now.
I have a 12 bits DAC circuit(on spectre), and it needs a input for the simulation.
However, the simulation data from the interpolator (previous stage) is generated by ModelSim, and its a text file with 0s and 1s~
Here is my question,
1. Can Spectre read text file as its input? or,
2. Do I need to build a VerilogAMS model to read the file and then generate 12 output signal for DAC as its input?
if so, how can I do that?
Thank your for your patience~
YiLi
YiLi
Re: text file for DAC input~
Reply #1 - Apr 19th, 2006, 9:06pm
can any one help??
or should I just build interpolator in to a symbol with verilog code and simulate with SpectreVerilog??
Reply #2 - Apr 19th, 2006, 11:04pm
It depends on the input format.
spectre can read vcd (Verilog Change Dump) format files these days (see the documentation for more
details - you'll need a recent MMSIM60 version for this).
Also, you could write a verilog-a model using $fopen()/$fscanf() to read the file.
Or if you can convert the data to a set of piece-wise-linear voltage versus time files, you could
just use vsource components with the type set to pwl.
YiLi
Reply #3 - Apr 20th, 2006, 7:19pm
Hi Andrew~!!
Thanks for your kindly reply~!!
but, I still have some questions:
What is MMSIM60? is that means I can't read VCD format file in IC5141?
Sorry, I can't attache the file here, so I just put some rows...
00000000000000
00000011111100
00000111100000
00001010010101
00001100001010
00001100110011
00001100001101
00001010011011
I guess I will thry the $fopen()/$fscanf() to read the file...
(I thought verilogA does not contain fscanf?)
change the file to PWL seems too complecated...
Thank you~
Best regards,
YiLi
YiLi
Reply #4 - Apr 20th, 2006, 8:33pm
sorry, one more question...
I've tried to use
integer infile;
integer vd[13:0];
infile = $fopen("file.dat", "r");
$fscanf(infile, "%d", vd[13:0]);
however, I want the outputs to be 14 electrical pins, and the vd[13:0] contains only integer!
so I can't transfer the digital 0100110101 to a voltage output~~
V(vd1) <+ transition( vd[13], tdel, trise, tfall );
how can I do now?
please help me~~
Thank you~
YiLi
jbdavid
Reply #5 - Apr 21st, 2006, 12:38am
with IC5141 there is a library called bmslib
it has a few verilog-a models in it..
a helpful one in thls case is busset8 - to show you how to take integer -> 8 bits out..
(thats tested and what folowes isn't .
what you want to do is read the integer from the file then set 14 outputs based on that integer..
module file2source (out, clk, gnd);
output [13:0] out;
electrical [13:0] out;
input clk;
electrical clk;
inout gnd;
electrical gnd;
parameter vhi = 1.5;
parameter vlo = 0;
parameter tr = 20p;
parameter tf = 20p;
integer vd[26:0]; // number of samples to read from the file if doing it all at once?
integer vd; // holds the entire integer value if reading from the file until its empty
integer infile;
analog begin
 @(initial_step) begin
   $fscanf(infile, "%d", vd); // only reading 1 integer (integer has 32 bits)
 @(cross(V(clk,gnd)-0.5*Vhi, 1)) begin // posedge
  // what if EOF?
 generate i (13, 0)  begin
   V(out[i],gnd) <+ transition((vd & 1<<i)?vhi: vlo, 0, tr, tf);
// note this form of generate statement is deprecated syntax.. but still works in 5141..
and mmsim6.. there is a newer form of the syntax in the AMS2.0 LRM, but last time I tried that
I think it didn't work in 5.0.33 (now in EOL - but I still have to support it for a while yet.. so I'm waiting a little longer
before going to the new syntax..  you may be luckier..
OR you could run spectreVerilog
OR you could run AMS designer, and write your DAC to use Logic input values (some examples of that in bmslib too..
but AMSD takes 3 tokens..
G'luck!
jbd
jbdavid
