Aug 18th, 2024, 7:28am
pss with mixer and frequency divider (Read 1880 times)
chase.ng
penang/malaysia
May 04th, 2006, 1:52pm
I am new to RF design, and I need to simulate a receiver. A build in divide-by-2 is present in the circuit and therefore the LO input is 2 times of what I will be using for the actual mixing. The problem is that I cannot get the pss to calculate the correct output harmonics I needed. Is there anyway to get around this?
Chase
Chase
View Profile chase.ng   IP Logged
ACWWong
Oxford, UK
Re: pss with mixer and frequency divider
Reply #1 - May 5th, 2006, 8:34am
Hi Chase,
In the pss form, ensure you have unticked "auto calculate" for the pss fundamental, and enter the number yourself.
For example, if the only large tone in your testbench is the LOsource @2G and you know there is a divide-by-2, then you set the pss fundamental to 1G.
Cheers,
aw
