Sep 19th, 2026, 6:15am
plotting verilog-a internals? (Read 7583 times)
danmc
Boston
May 06th, 2006, 8:10pm
anyone know how (if possible) to plot an internal signal (electricaltype in my case) from a verilog-a module?  The signal does not go to a pin.  I'm using cadence.  I took a look in the results browser in analog artist but didn't see any of the internal nets inside the veriloga model.
-Dan
Re: plotting verilog-a internals?
Reply #1 - May 6th, 2006, 8:26pm
Dan,
  Doing this from memory, in the Outputs --> Save All window, select
save ahdl variables radio button. This should allow you to save and
plot the variables. However, you may need to access them from the
Results Browser.
danmc
Boston
Reply #2 - May 7th, 2006, 7:28pm
This almost works.  I now see anything of type 'real' in the results browser, but still no 'electrical' ones.  So, for now I just stuck in:
electrical foo;
real vfoo;
analog begin
vfoo = V(foo);
// other stuff
to make my signal show up as a real.
-Dan
Reply #3 - May 8th, 2006, 5:18pm
Dan,
 Oops in that case, try setting the option "select signals to output
(save)" to all in the Outputs --> Save All...  window. Eletrical nodes
internal to a behavioral model are not public and are not saved by
default (as I remember).
ACWWong
Oxford, UK
Reply #4 - May 8th, 2006, 11:36pm
Yes, default is "allpub", so changing it to "all" should give all internal nodes....
