Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 1:10pm
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› could I find FM source with rail-to rail output?
Previous topic
Next topic
could I find FM source with rail-to rail output? (Read 2570 times)
jcpu2006
Hsinchu
May 07
th
, 2006, 10:53pm
Dear Sir:
I need help to find a voltage controlled source
whose frequency can be adjusted by <VTUNE>
with rail-to rail (square wave) output.
Or say it is a VCO with square-wave output.
in ADE environment.
Thanks in advance.
IP Logged
ACWWong
Oxford, UK
Re: could I find FM source with rail-to rail outpu
Reply #1 -
May 8
th
, 2006, 2:29am
Try the vco in ahdlLib supplied by cadence. It is a veriloga view. you modify the code for you own needs, or stick an inverter/limiter on the output to get your square wave.
$INSTALLATION_ROOT/tools/dfII/samples/artisit/ahdlLib
IP Logged
Reply #2 -
May 8
th
, 2006, 10:48pm
There are also Verilog-A VCO models at
www.designers-guide.org/VerilogAMS/
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
