Aug 16th, 2024, 2:48pm
self biased opamp in LDO (Read 4358 times)
grosser
May 08th, 2006, 5:06am
hello
could you tell me how to design a startup circuit in attached schematic?
bias current depends on load current. without startup circuit M0 goes into cutt-off
regards
zhonghan
china
Re: self biased opamp in LDO
Reply #1 - May 11th, 2006, 2:00am
in attachment is my reply ,all scales of  transistors are not correct .
grosser
Reply #2 - May 12th, 2006, 2:38pm
how is the opamp's bias current set?
M3's drain voltage is set to Mout give wanted load? this drain voltage determines M3's current andso on??
what if load current IL is small?
regards
Reply #3 - May 15th, 2006, 6:30pm
Hi, Grosser,
There are many descriptions about start-up circuits in some textbooks. I think they could be used in your self-biased opamp. Please select one book in Designer's Guide Book List.
http://www.designers-guide.org/Books/
Best regards,
Yawei
